It is currently 19-Aug-2026 16:07:52
Post new topic  Reply to topic  [ 1 post ]
PostPosted: 15-Jun-2004 10:57:12
Iznaakusi visiem ieteicamaa - Synapse.Audio.Orion.Platinum.v5.5
Orion Platinum is a complete virtual studio, including multitrack
audio recording, a mixing desk with sub busses and effect returns,
as well as powerful sequencers, generators and effects. All common
interfaces, ReWire2, VST and DirectX are fully supported. Orion
Platinum ships on CD with a 600 MB library of more than 800
royalty-free presets and high quality multisamples. Demo songs and
tutorials are included as well.
Using the four-bus Mixer and Master Section, you can build advanced
mixes in no-time, and the MultiFX control lets you create complex
effect routing.
High resolution post-production is made possible by the enhanced
WAV exporter, which supports up to 32-bit / 96 kHz resolution and
can render instruments or channels to multiple WAV files.
As the chart on the right shows, the Platinum edition supports very
high audio resolutions.
Orion Platinum comes with a selection of 35 internal effects -
including reverb, delay and chorus effects, a full parametric
equalizer, and more. Additionally, there is full support for
third-party VST and DirectX effects, as well as for third-party VSTi
and DXi instruments.
New in v5.5:
• new Screamer Generator
• new Platinum Reverb effect
• MIDI Song import function
• AutoScroll in piano roll can be turned
on/off (press 'cfg' button)
• AutoScroll in playlist can be turned
• Better sequencing when working with very
long patterns or MIDI files
• Piano roll: jumps to last edit position
now, both x/y location is remembered when
leaving piano roll.
• All standard drum presets are now
programmed for 4 stereo outs as well.
• 3/4, 5/4, 7/8 etc signatures now
sequencable by changing the playlist grid
(cfg button).
• Auto-Snap to Zero in Groove Slicer by
pressing F11 or S
• F12 uses the PC keyboard as an input
device to play notes (F2-F9 toggles octave)
Users browsing this forum: No registered users and 28 guests
