It is currently 08-Aug-2026 3:40:15
PostPosted: 13-Jul-2011 14:46:31
Sveiki!
Radās tāds jautājums kā šos aparāturs iedarbināt, lai viņi randomā maina attēlus un kustās savienojot paralēli ar XLR vadu?
Pagaidām savienojot visus kopā, visiem mainās vienādas krāsas, bet nekustās.
Mērķis ir dabūt, lai visi skaneri saslēdzot kopā bez kontroliera kustētos un visi mainītu vienādas krāsas.
Vai tas ir izdarāms paspaidot podziņas, bez kontroliera palīdzības.
PostPosted: 17-Jul-2011 11:09:05
http://www.americandj.com/ProductDetail ... SCONTINUED , te ir rakstīts ka tas ir iespējams ,
• Linkable in master/slave operation via XLR cables .
Tātad Tev vajadzētu paņemt DJ Scan 250 EX User Manual (pdf)
un izlasīt sekojošu tekstu :
Master-Slave Operation (Sound Active): This function will allow you to link up to 16 units together and operate without a controller. The units will be sound activated. In Master-Slave operation one unit will act as the controlling unit and the others will react to the controlling units programs. Any unit can act as a Master or as a Slave.
1.
2.
3. 4.
5.
Using standard XLR microphone cables, daisy chain your units together via the XLR connector on the rear of the units. Remem- ber the Male XLR connector is the input and the Female XLR connector is the output. The first unit in the chain (master) will use the female XLR connector only - The last unit in the chain will use the male XLR connector only. For longer cable runs we suggest a terminator at the last fixture.
On the Master unit use the MENU button until “SLND” is displayed press ENTER. Either “MAST”, “SL 1” or “SL 2” will be displayed. Press the UP or DOWN buttons to set the fixture to “MAST”, and press ENTER.
On the slave units tap the MENU button until “SLND” is displayed, press ENTER. Set the fixture to either “SL 1” or “SL 2” and press ENTER.
The slave units will now follow the Master unit. Note: When running fixtures in Master/Slave configuration “SL 1” will make the fixture do the opposite to the other fixture. Example: Four fixtures linked together. On fixtures 1 and 3 set the fixture 1 to “MAST” and set fixture 3 to “SL 1”, and set fixtures 2 & 4 to “SL2”. Fixtures 1 & 2 will run the same and fixtures 2 & 4 will run opposite. This makes a great light show.
The optional UC3 Controller (not included) may be used to con- trol different functions including blackout.
lai veicās :)
