It is currently 12-Aug-2026 18:53:22
 Post subject: Fairchild 670
PostPosted: 16-Aug-2010 18:42:24
Infai, pasaulee visdaaraakaa kompresora/limitera Fairchild 670 autors izraadaas ir igaunis Rein Narma.
The origins of the 670 (and mono 660 version) are fairly humble, coming from Estonian-born Rein Narma. In the post-war years, this refugee from Soviet Russia worked for the U.S. Army as a broadcast/recording tech during the Nuremberg trials, later immigrated to the New York and took a job at Gotham Recording. Narma and several others founded Gotham Audio Developments, to build recording gear. Les Paul hired him to modify his first 8-track and later Narma built consoles for Rudy Van Gelder, Olmsted Recording and Les Paul, who also asked him to build a limiter. After beginning the project, Sherman Fairchild heard about it, licensed the design and hired Narma as the company's chief engineer. After a stint at Fairchild, Narma moved to Northern California and was a vice-president at Ampex.
Speeciigi!
 Post subject: Re: Fairchild 670
PostPosted: 17-Aug-2010 8:56:44
Nu jaa, kaut kas lidzigs Walter Zapp legendai :)
Man tik viens jautajums rodas, ja jau kompresora butuba ir sacakaret skanu (samazinat dinamisko diapazonu), tad kada nozime tam vai to dara loti dargi vai vienkarsi dargi - nu tas ta globali raugoties :)
PostPosted: 17-Aug-2010 10:20:32
Man, diemžēl, nav nācies saskarties ar dārgā gala HW kompresoriem. Visa fiška ir kā kompresors reaģē uz t.s. "transients" (vienkāršoti - skaņas sākuma fāze), vai tā tiek sačakarēta, vai nē. Tas ir ja mēs runājam par dinamisko kontroli, tobiš nepārforsējam. Te dārgais gals ieliek. Ja runā par kompresoru kā efektu, tad te der da jebkas, atkarībā no situācijas. Un jā, ir daudzi inženieri, kas šo Fairchild izmanto, lai vienkārši izlaistu skaņu cauri. Maybe ar kompresiju max 0.5-1 db. Tas dēļ THD. Nu tur "siltums" un visas tās ezotēriskās lietas :)
p.s. Caps, kā izrādās, arī EE būdams, sācis savu Minox.
