It is currently 16-Aug-2026 5:28:30
 Post subject: QSC GX 5
PostPosted: 28-Sep-2009 12:38:30
sveiki, ir doma iegādāties šādu aparātu, ko sakat? cena tāda aizdomīga, un sapratu , ka laikam uz 2 omiem nestrādā, bet varbūt bez tā var iztikt
GX Series
SPECIFICATIONS GX3 GX5
8 ohms / 1 kHz (both channels driven) 300 W 500 W
8 ohms / 1 kHz (single channels driven) 350 W 600 W
4 ohms / 1 kHz (both channels driven) 425 W 700 W
4 ohms / 1 kHz (single channels driven) 500 W 850 W
Distortion (typical)
20 Hz - 20 kHz, 1 dB below rated power
8 ohms: less than 0.05%
4 ohms: less than 0.1%
Signal to Noise (20 Hz - 20 kHz) 100 dB
Input Sensitivity 1.2 Vrms
Voltage Gain (8 ohms) 32.2 dB 34.4 dB
Output Circuitry Class B 2-tier Class H
Power Requirements (1/8 power, pink noise at 4 ohms, 120V) 6.3A 6A
Frequency Response 20 Hz - 20 kHz, +0, -1 dB
Dynamic Headroom (4 ohms) 2 dB
Input Impedance (ohms) Greater than 20k (balanced)
Maximum Input Level
+24 dB (16 Vrms)
Input Connectors (each channel) 3-pin XLR and 1/4" TRS, balanced, parallel
Phono, unbalanced
Output Connectors (each channel) Speakon®, 1/4", Binding Posts
Amplifier and Load Protection Short circuit, open circuit, thermal, RF protection
Load protected against DC faults
Front Panel Controls and Indicators Gain controls, 21 detents
Red Clip LEDs, proportional, 0.1% THD threshold
Green Signal LEDs, threshold -35 dB
Blue Power LED, AC on
Rear Panel Controls Full Range / Crossover switch
100 Hz, 3rd order LP (sub), 2nd order HP (top)
Dimensions Height: 3.5" (89 mm) 2RU
Width: 19" (483 mm)
Depth: 10.1" (257 mm)
Weight Net: 27 lbs (12.1 kg)
Shipping: 31 lbs (14.1 kg) Net: 28 lbs (12.6 kg)
Shipping: 32 lbs (14.6 kg)
Agency Approvals UL, CE, RoHS/WEEE Compliant
AC Power Consumption
AC Current and Heating, 120 VAC
GX3 GX5
Operating Condition AC amps BTU / hr AC amps BTU / hr
Idle 0.2 44 0.3 60
8 + 8 ohms, 1/8 power 1 4.1 904 3.3 734
8 + 8 ohms, 1/3 power 2 6.1 1160 8.5 1456
8 + 8 ohms, full power 3 9.75 1109 16.2 1891
4 + 4 ohms, 1/8 power 1 6.3 1515 5.8 1160
4 + 4 ohms, 1/3 power 2 9.4 2105 11.2 2162
4 + 4 ohms, full power 3 15.0 2297 24.5 3754
1 1/8 power represents typical operating conditions
2 1/3 power represents peak program levels
3 Full power is breaker limited to short periods
For 230 V, multiply AC current by 0.5
For 100 V, multiply AC current by 1.25
* At onset of clipping
All Specifications Subject to Change Without Notice.
GX Series Rear Panel
Inputs
XLR, 1/4" TRS and phono input connectors for compatibility with any source. Crossover
Subwoofer/Satellite crossover built-in. Outputs to Speakers
Speakon® combo output connector accepts 1/4" or Speakon 2 wire connectors.
Binding post output for compatibility with any loudspeaker wiring scheme .
 Post subject: Re: QSC GX 5
PostPosted: 28-Sep-2009 13:43:51
Ampam nav ne vainas :)
Raksti DDFF PM :)
PostPosted: 11-Nov-2009 1:02:06
iegādājos divus gabalus, un pagaidām izskatās ka ir ok.. :) monitoriem strādā labi.. :)
