It is currently 07-Aug-2026 0:07:21
PostPosted: 25-Oct-2007 8:20:13
Iznākusi Cakewalk Sonar 7 versija - http://cakewalk.com/Products/SONAR/English/default.asp
Interesanti, ka tagad jau komplektā ir iekļauts krutais sintezators Z3TA+ - http://cakewalk.com/Products/Z3TA/Default.asp
Tas bija pirmais, kas man iekrita acīs. Pārējo vēl neesmu izpētījis ...
Jaunumi
Instrumenti:
# Dimension LE (with Garritan Pocket Orchestra)—real instruments and advanced synthesis
# Rapture LE—modern synthesized sounds
# Z3TA+—incredible analog-style sound shaping capibilities; waveshaping synthesizer (jau iepriekš minēju)
# DropZone—drag & drop sampler and REX loop Editor.
Audio Efekti:
# LP-64 EQ—linear phase mastering EQ
# LP-64 Multiband—linear phase multiband limiter/compressor
# Boost 11 —peak limiter
Citas lietas:
# VC-64 Vintage Channel™ with sidechaining capabilities
# Roland V-Vocal™ 1.5 with Pitch to MIDI conversionetc
Sistēmas prasības
minimālās:
# Windows XP
# Intel Pentium 4 1.3 GHz, AMD Athlon XP 1500+, or higher
# 256 MB RAM
# 1024x768, 16-bit color graphics resolution
# 100 MB hard disk space for full program installation
# Any Hard Disk Type
# Windows-compatible MIDI interface for connecting MIDI devices
# Windows-compatible audio interface for audio playback
# DVD-ROM, DVD+/-R, or DVD+/-RW Drive required for installation
rekomendētās:
# Windows XP/Vista (32 and 64-bit), can be run on Mac OS X with Boot Camp
# Intel Pentium 4 2.8 GHz [EM64T], AMD Athlon 64 2800+, or higher
# 1 GB or higher RAM
# 1280x960, 24-bit color or higher color graphics resolution
# 6 GB hard disk space
# EIDE/Ultra DMA (7200 RPM) or SATA Hard Disk Type
# WDM- or ASIO-compatible audio interface for audio playback (see cakewalk.com for complete list)
Video par Sonar 7 - http://cakewalk.com/Products/SONAR/Engl ... videos.asp
!!! Citēju "ir jau 7.0.1." - visādi updeiti, labojumi etc. - http://www.cakewalk.com/support/kb/kb20071015.asp
Nu jau 7.0.2 (Cakewalk® Releases Free SONAR 7.0.2 Update and Euphonix EuCon Compatibility)
Būtībā tas viss ir atrodams viņu mājas lapā ...
I n d i c a t i v e
PostPosted: 25-Oct-2007 12:44:16
ir jau 7.0.1. :D
PostPosted: 25-Oct-2007 12:50:28
ir jau 7.0.1. :D
Pilnīgi pareizi - http://www.cakewalk.com/support/kb/kb20071015.asp
...:wink:
I n d i c a t i v e
PostPosted: 18-Jan-2008 0:15:56
Lai lieki neveidotu jaunu topiku;
jaunums par Sonar/Cakewalk tēmu:
"Roland To Acquire Major Share of Cakewalk".
Turpmāk Cakewalk produkcija tiks saukta "Cakewalk by Roland".
http://news.harmony-central.com/Newp/20 ... ition.html
Laikam jau tikai likumsakarīgi, ja ņem vērā, kaa Steiberg ir Yamaha īpašums, Logic pieder Apple, Sounforge - Sony, utt., u.tml.
Interesanti, kādus rezultātus tas nesīs (kaut vai hardware/software apvienotu risinājumu nozīmē); piemēram, Steinberg gadījumā, šķiet nekādi īpaši rezultāti vai izstrādājumi no tā piederības Yamahai nav radušies.
PostPosted: 18-Jan-2008 9:31:59
ESmu vairāk kā pārliecināts, ka būs viss sūdīgāk. Lielas kompānijas, neelastīgas, klientu serviss klibo...reāls piemērs Mackie. Bija Tracktion, ļoti daudzsološs sekvencers. Tā arī palika "daudzsološo" listē.
No otras puses, abiem sadarbība ir cieša jau gadiem, varbūt tāpēc likumsakarīgi.
Vēl. Bija tāds rgc audio, džeks argentīnietis, z3ta+, pentagon coders. Šo pārpirka Cakewalk. Attiecīgi rgc kompānijai jok. Kaut ko jau šis dara, vairumā gadījumu tikaiu eksluzīvi cakewalkam, bet nu konkrēti, nav vairs tas...Īsāk, klients no šādiem pārpirkumiem/pārņemšanām cieš vairāk nekā iegūst.
PostPosted: 20-Jan-2008 19:46:18
jebkuraa gadiijumaa lai vai kas un ko paarpeerk es uzskatu ka labums vienmeer ir, jo patssaproti ka tie kas taisa VSTi nevienmeer 100% parzin hosta vaajaas un speeciigaas puses , automaatiski ja hosta rakstiitaajs paarpeerk kaadu no VSti tad vinsh vinju pielabo lai viss darbotots nevainojami
PostPosted: 22-Apr-2008 7:59:15
Release date: January 4th, 2008 (jau diezgan sen)
PostPosted: 03-May-2008 9:48:54
Džeki atkal izlaiduši grāmatu - Cakewalk SONAR 7 Producer Edition. Запись и редактирование музыки (Петелин Р.Ю., Петелин Ю.В.)
Skatīt saturu ...
Veikalā "Viss datoram 636" to nopirku. Cena Ls 8 ar kapeikām ...
PostPosted: 26-Sep-2008 15:32:41
Esot jau 8-tā -> lasīt ...
