It is currently 21-Oct-2026 9:45:50
 Post subject: mal
PostPosted: 13-Sep-2007 14:31:44
defank - mal
http://yy.lv/download.php?f=70850
braindance
 Post subject: Re: mal
PostPosted: 13-Sep-2007 18:59:30
yy.lv jau kā vienmēr parslodze, stulbums
PostPosted: 14-Sep-2007 19:31:43
!!! 18000 clipped samples !!!
Maybe tomēr nevajadzētu publicēt tādus brāķus...
PostPosted: 14-Sep-2007 20:14:07
kas ir 1800 clipped samples? :roll:
braindance
PostPosted: 14-Sep-2007 23:36:31
Palasi kādu skaņu apstrādes literatūru...
PostPosted: 14-Sep-2007 23:43:54
nu ja esi tik gudrs varētu arī pats paskaidrot...nevis izspļaut kaut kādu terminu un domāt ka ir baigi gudrs.
braindance
PostPosted: 15-Sep-2007 0:23:50
Tev jau te kroplis ar ausi dzirdams, pļerkst kā izsists skaļrunis...
Jebkurā audio editorā (CoolEdit, SoundForge, Wawelab u.c). tas ir redzams.
Pie pareizas apstrādes "Possible clipped samples" būtu jābūt 0.
Code:
Clipping
Both analog and digital media have an upper limit beyond which they can no longer accurately represent amplitude. Analog clipping (or overdrive or distortion) varies in quality depending on the medium. A tube amplifier, for example, has a much warmer distortion than a solid state amplifier. In each case the upper amplitudes are being altered, distorting the waveform and changing the timbre, but the alterations are slightly different. Digital clipping, in contrast, is always the same. Once an amplitude of 1111111111111111 (the maximum value in a 16 bit resolution) is reached, no higher amplitudes can be represented. The result is not the smooth, rounded flattening of analog clipping, but a harsh slicing of off the top of the waveform, and an unpleasant timbral result.
Avots: by David Ozab
PostPosted: 15-Sep-2007 1:26:30
Tembri pļerkst un klipings pļerkst vienotā, bet, tajā pašā pašā laikā disharmoniskā, unisonā. Skanējums rada apmēram tādu iespaidu - sinhronizēti palaisti divi sekvenseri, no kuriem katrs atskaņo savu melodiju un pavadījumu, bez tam viens no tiem ģenerē visādus errorus.
PostPosted: 15-Sep-2007 12:39:44
Pēc šādas prezentācijas paklausījos skaņdarbu. Ārprāts, cilvēk, kur ir tavas ausis?? Te jau nemaz nevajag analizatoru.
Šis ir no sērijas:
- Dēliņ neej uz tām skaļajām diskotēkām, kurls paliksi!
- Paldies, esmu jau paēdis!
PostPosted: 15-Sep-2007 13:14:03
:D labi...būs jādara kaut kas lietas labā
braindance
PostPosted: 15-Sep-2007 13:43:55
jeibogu...
PostPosted: 27-Sep-2007 10:52:37
pielabots...
braindance
Users browsing this forum: No registered users and 11 guests
