It is currently 07-Aug-2026 15:46:08
 Post subject: Coaxial Digital Cable
PostPosted: 21-May-2006 22:55:36
Jautajums:
1) Kadus labak pirkt?
2) Kur?
3) Kadas cenas?
Paldies.
PostPosted: 21-May-2006 23:02:12
Domaju derees visparastaakais TV kabelis , arii galus (konektorus) var nopirkt shaagaam vajadziibaam , pat jaalodee nekas nebuus .
Gruutaat buutu ja vajadzeetu optiku .
PostPosted: 22-May-2006 8:39:09
TV kabelis vareetu darboties iisiem gabaliem- neesmu meeginaajis. Galvenaa atshkiriiba ir viljnja pretestiiba, kas TV (RG59, RG11, RG6 peec ekvivalenta) ir 75 oHm, toties AES/EBU (balanceets digital) vai SPDI/F (nebalanceets) ir 110 oHm. Taapat jaasaktaas vai dotajaam TV kabelim nav liela paraziitiskaa kapacitaate pie freq. augstaakaam par 500 MHz. Konektori, cik nojaushu, ir parastaakie RCA- var dabuut skruuveejamus, taapat arii lodeejamus. Iespeejams, ka leetaak buus nopirkt gatavu kabeli.
PostPosted: 22-May-2006 8:54:18
TV kabelis tomer paliek TV...
pats taisit negribu, gribu nopirkt gatavu...
PostPosted: 22-May-2006 11:32:16
Sveiki
Nu Tu ddff iekriti: :lol:
Here is a short comparision table of AES/EBU and S/PDIF interfaces:
AES/EBU
Cabling 110 ohm shileded
Connector 3-pin XLR
Signal level 3..10V
Modulation biphase-mark-code
Subcode information ASCII ID text
Max. Resolution 24 bits
S/PDIF (IEC-958)
Cabling TP 75 ohm coaxial or fiber
Connector RCA (or BNC)
Signal level 0.5..1V
Subcode information SCMS copy protection info
Max. Resolution 20 bits (24 bit optional)
Kā reiz derēs 75 Om kabelis priekš SPDIF interfeisa..........
PostPosted: 22-May-2006 11:51:56
Ak redz kaa- visu laiku uzskatiiju, ka s/pdif ir nebalanceets AES/EBU (kas taa arii ir, jo man pasham lietoshanaa ir paarejas transformatori), tachu nekad nebiju iedomaajies ka tiek mainiita arii slodzes pretestiiba...
Sveiki
AES/EBU
Connector 3-pin XLR
Signal level 3..10V
S/PDIF (IEC-958)
PostPosted: 22-May-2006 13:19:41
man vajag ar RCA konnektoriem.
atradu ka ir KLOTZ kabeli... ... 3m cena ~13 EUR
Kur Rigas centra ir veikali, kuros ir uz vietas kabelji? Unisons? Tava Skanja? ... ?
Kadas firmas kabeli labak njemt?
THNX
PostPosted: 22-May-2006 13:23:31
Negribu būt nepieklājīgs pret fiziku, bet domāju ka nav jēgas vispār saspringt uz 3m, paņem normālu audio kabeli un viss Tev strādās :lol:
PostPosted: 22-May-2006 15:09:38
Prieksh kam pirkt Marantz? Radiotehnika ari skan...... :)
Ja shadus kabeljus razho firmas, tad droshvien labak izmantot tas kuri ir domati shim merkim... nevis njemt kadu citu analogiju...
un man sheit nebija jautajums, ka tadu kabeli uzmaistarot un no ka..... jo ari merkjis nav tads....
PostPosted: 22-May-2006 15:27:18
Atvaino.
Domāju ka Tev vajadzēja vienkārši atrisināt vienkāršiem līdzekļiem problēmu.
SPDIF kabeļus tev nopārdos ,nešaubies būs krāsaini un smuki.
P.S. Es pats mājās klausos uz Marantz un Parasound bet tas nenozīmē ka esmu gatavs škiesties ar naudu tur kur tas kvalitāti neietekmē.
PostPosted: 22-May-2006 18:40:54
Principaa nesaspringstot jebkurshs muussdienu TV kabelis uz triis metriem bez zudumiem ir speejiigs laist cauri virs 2 Ggz , un tas tev izmaksaas 0.9 LS + skruuvejamo RCA konektoru komplekts max 1.2 LS .
Protams buus vainu balts vai melns .
PostPosted: 22-May-2006 19:48:52
.. iegaju shodien viena veikala .....
paprasiju.... ja ir .... cena .... :D ... 40Ls... (nu tas bija kaut kads shausmigi krutais)
un vel dzheks iegruzija ka ja vajag 3m - tad tas tipa jau vispar shit sanak....
protams es zinu ka labak ir tad kad kabelis isaks, bet ja iet cipars man liekas tas jau pavisam cita lieta...
PostPosted: 22-May-2006 21:03:54
Kaa redzi Girts bij tuvaak patiesiibai kaa tu vari iedomaaties .
40 LS :shock: , vijsh ko tiirs no zelta :?
PostPosted: 22-May-2006 21:34:20
nezinu no ka vinjsh tur bija.... bet vel bija parastie RCA kabeli pa 60, 80 Ls... varbut ari vairak... un tas ir standarta garumi.. laikam lidz 1.5m
PostPosted: 22-May-2006 21:48:39
Vēl mazliet par šo tēmu:
Labāk ,ja ir iespējams izmantot priekš SPDIF optisko savienojumu jo mēdz būt aparātiem potenciālu starpība uz korpusiem.
Bet Tev laikam ir svarīgi šie 3m kas ir diezgan tālu priekš parastā plastmasas vada.
