It is currently 06-Aug-2026 12:18:17
 Post subject: Drum & Guitar
PostPosted: 01-Nov-2004 12:57:21
1. Vai ir speciali domati sintinji ar ko var veidot pats savas drum skanjas - kickus snares hihatus un pectam taas parveidot uz WAV lai varetu ielikt kaadaa drum mashinaa vai kur citur? Ja ir,tad kuri ir tie labakie?
2. Un vai ir sintinji no kuriem var izdabut araa kaut cik dabigas smagaas gitaras skanjas un ari parveidot uz WAV?
PostPosted: 01-Nov-2004 15:04:30
speciaali tam domaatu sinthu manupraat nav...uz jebkura normaala syntha tu vari meegjinaat taisiit pats savas skanjas, kaut gan drum un guitar taisiishanaa tu neko jaunu neizdomaasi- synth paliek synth.. :wink:
Native instr.Pro -53, Absynth, Virsyn Terra to sinthu ir kaudzeem...
eksperimentee :lol:
PostPosted: 02-Nov-2004 15:10:24
Nu vispaar ir taadi drum sintiji, viens nu jau bankroteejushaas vaacu kompaanijas Waldorf masterpiece - Waldorf Attack. Tas gan pats neeksportee uz wav, jo ir VST plugins, taapeec vajadziigs ir hosts. Tad veel Linplug ir taads Element P. Visi shie ir sintinji, nevis rompleri, liidz ar to tiem ir n tviikoshanas pochu. Ir veel, ja nemaldos, Luxonic Ravity P...
s.
PostPosted: 02-Nov-2004 22:04:25
liekas, ka shis buus iistais prieksh tavaam veelmeem
Synapse Junglist VSTi v3.2
2 oscillators (32 waveforms) with adjustable coarse and fine tune
Saturation control for both oscillators
2-op FM mode
Percussive mode for synth drum sounds
Dual Voice mode
Ring Modulator
Multimode filter with 24 dB Lowpass, 24 dB Highpass types and Separation control
Filter Keyboard Tracking
2 pitch envelopes
ADSR filter envelope
ADSR amplitude envelope
LFO on pitch and/or filter
LFO and Delay tempo syncable
Glide function, can be switched between constant-rate and constant-time
Bass Fx section to create ultra-low basses
Complex Chorus section allows a wide range of delay, chorus, flange and spatialization effects
Distortion effect, low/high filter, and level for the master output
Supports both parameter automation and Cubase automation (MIDI CC)
Unison mode (plays all voices at once)
Up to 16 voices of polyphony
Supports Aftertouch
ed2k://|file|Synapse.Junglist.VSTi.v3.2-ARCTiC.zip|2232433|FD1F1CBE861B24C0D06E464F116EA01A|/
pumpee ar eezeli un kaifo....(tikai kaads tev hosts nezinu), ja tu gadiijumaa straadaa ar Acid (skatos, ka tas te ir baigi populaars), tad uzliec 5 versiju - taa atbalsta VST instrumentus (pameklee - es diezgan pasen iemetu forumaa linku uz Acid 5), ja tu lieto Steinberg hostus, tad vispaar nekaadu probleemu....
lai veicas :D
PostPosted: 03-Nov-2004 9:23:25
Junglist ir vairaak domaats kaa VA sintezators. Manis nosauktie ir tiiraas bungu mashiinas, respektiivi izdod tikai sitamo skanjas. No otras puses, ja juuzers zin VA principus, tad drumsoundus var uztaisiit no jebkura sintinja, t.s. Junglist. Piemeeram kicku, kaa Osc njemam Sine wave, tad taa frekvenci mazliet moduleejam ar Env Mod, bishkji firlter settingus un a la TR-909 kick gatavs. Liidziigi arii ar snare, tikai kaa otru Osc njemam Noise.
