It is currently 14-Aug-2026 10:30:24
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: 22-Aug-2005 12:05:52
Mhm, lai moderatori poshii! :P
PostPosted: 22-Aug-2005 17:14:55
platjoslas speakeris liekas beediigs. Sheemu vareetu uztaisiit, ja zinaatu kaut ko par HF driveri vairaak. Vajag jaudu, impedanci un freq. joslu. Filtrus nopirkt neizdosies- tie jaabuuvee un ja HF komponente buus tikpat seeriiga kaa LF, tad filts var maksaat juutami vairaak par to tumbu kopumaa.
Ne nopietni labs vai slikts ?????
Man tad atsutis kaut kas shemu ar labkiem filtirem un kur tos nopirkt ??
PostPosted: 22-Aug-2005 17:16:55
cilveek, nevar tak seedeet un klabinaat cauraam dienaam- arii maiziite jaapelna. Tagad PV tuure ir cauri, nu varu apseesties un parakstiit.
Kaut ko ilgi kavejas atbilde :cry: :cry: buss sagaidama
PostPosted: 23-Aug-2005 11:21:32
Laikam tomer tad vaina ir LF Dinamikos :( , ko jus varetu ieteikt varbut pardod ?
sos dinamikus un nopirkt tadus kuri tiesam ir labi ??
Un cik tadi maksatu ? :?
PostPosted: 23-Aug-2005 18:48:20
Skytronic
902.439
PRO MUSIC WOOFERS WITH ALUMINIUM FRAME
Trade Prices Available ...
This PRO-MUSIC series are constructed from heavy-duty die-cast aluminium frames and incorporate a strong 3"/7.5cm Kapton voice coil, coated paper cones. This special design ensures a perfect reproduction of the bass frequencies and makes these speakers ideal for large sound combinations. Fitted with gold-plated push terminals for quick connection. • Aluminium chassis
• Vented magnets
• Gold plated push terminals
Patiesiibaa jau spriezhot peec bildes tas tev ir traapiijies viens taads itkaa zemo frekvenchu skaljrunis taatad lai maksimaali no shamaa dabuutu laukaa aukshas galu vajadzees to filtru no taas kastes reanimeet jaa taa var teikt , zheel kad netaa nau shamajam atrodama raksturliikne bet taa ciitiigi apluukojot shamajam eksemplaaram bildi tomeer rodas doma kad difuzors ir pietiekoshi biezs un taatad arii smags kaa rezultaataa stipri shaubos kad shameejais buus speejiig atskanjot frekvences virs 4000 .
Katraa gadiijumaa peec apraksta nau jau tas labaakais dinamiks bet lietot noteikti var un jau seviskji ar tavu SONY sapnju kalngalu , vieniigi jaanjem veera to kad taveejais SONY super sound atskanjo 100 vatus pie 4 omu slodzes pretestiibas kur tavaa gadiijumaa ir 8 omi skaljrunja pretestiiba taatad labaakajaa gadiitumaa tavs SONY supe sound ir speejigs shamo difuzoru noslogot par 50 vatiem .
Patiesiibaa jau tavaa gadiijumaa vajadzeeja padomaat par kaadu AUTO 15 collu dinamiku . Buutu kaa aamurs naglai uz galvas un iespeejams arii smukaa kaste nebuutu jaapaartaisa , bet kaste tieshaam izskataas pat ljoti labi .
Par to augsheejo frekvenchu dinamiku , nu nezinu vai ir praatiigi maajas kastei izmantot taadas konfiguraacijas verkji . Katraa gadiijumaa noteikti izteereetaa naudas summa neattaisnojas .
Mans ieteikums nopeerc DIVUS KOMPLEKTUS S_90 [8 OMI] un esi ka tu raams. Buss gan tavs SONY super sound noslogots labi gan pashas skandas paliks dziivas .
PostPosted: 23-Aug-2005 18:57:37
ieteiktu nodot visu to uz svaru un aizmirst sho lietu. Tas 15" ir tieshaam kaa LF speakeris, tas noziimee, ka diez vai aizvelk liidz 1kHz bez spektra kropljojumiem. Jau labam 12" ar vieglu membraanu parasti pie 1K griezh nost joslu, shim varbuut pat zemaak. Tas noziimee, ka ir vajadziigs sasodiiti labs HF driveris, lai tureetu liidzi tam 15". Iisteniibaa projekts sevi neattaisno, taapeec iesaku atrast kaadu lietderiigaaku laika pavadiishanas veidu.
PostPosted: 23-Aug-2005 19:11:20
DJ igor es to visu zinu ko tu stasti bet neticu ka tas ir zemo frekvencu dinamiks un negribu so projektu beigt jo sis tumbas nebus domatas majai !!! un sony pastuzim ! iesakiet labak kaa rikoties ??? vai pirkt citus LF un citus HF ??? Tad ta4u viss butu labi netaisos beigt so darbu dinamiku del ! :evil:
PostPosted: 23-Aug-2005 21:23:18
Nu redz kaa izraadaas Latvijaa ir leerums visaadu skandu tirgotaaju bet ieteikt cilveekam vienu HF fonoru taa arii neviens nevar , taadad naudu nevajag bet cilveeks ir gatavs maksaat . Kaa raadaas .
PostPosted: 23-Aug-2005 22:32:36
labi! Ja gribas parosiities idejas vaardaa, tad tas ir apsveicami un shaadu veelmi apspiest negrasos. Saakam ar to, ka jaadabuu skaljrunja Thiele- Small parametri. Tas atradaas sheit: http://www.skytronic.com/rsc/doc/thielesmall_902127.pdf Tad varam kjerties pie filtru reekinaashanas shim te skaljrunim (izmantosim 3. kaartas Butterworth LoPass filtru un iespeejams arii paaris Notch filtrus). Labaakais veids to ir dariit ar JBL SpeakerShop programminju, kurai ir arii Filters Utility- reekjina labi. Atceries, ka saakumaa ir jaaizveelas filtru tipi un jaauzbuuvee pats krosovers, tad jaapadomaa par atenuaaciju HF driverim (L-pad kjeede) un visbeidzot Notch. Lai nebuutu ar karoti mutee liets piedaavaaju palasiit pashus pamatus par audio signaala kroseeshanas piemeeriem (ar visiem filtru kalkulatoriem)- http://www.lalena.com/audio/faq/xover/ Un ja nonaaksi liidz buuveeshanai- neaizmirsti padomaat par komponentu jaudaam- kaa taas apreekinaat maaca vidusskolas fizikas kurss. Taapat arii nezheelo naudu polipropileena kondensatoriem- atshkjiriiba no elektroliitiskajiem vai tantala ir graujosha. Veelu veiksmes un turpmaak uzdod jau vairaak fokuseetus jautaajumus.
PostPosted: 25-Aug-2005 22:07:22
Paldies par so informaciju nakosie jautajumi bus fokuseeti
 Post subject: Dinamiki
PostPosted: 27-Aug-2005 20:44:42
Vai nevaretu ietekt, kur varetu iegadaties speakeru un filtru komplektu. Kas butu lidzvertigs akustiskai sistemai, tadai kaa piemeram JBL JRX115 vai lidzigam 15'' akustiskam sistemam par pienemamu cenu
Seit ir apraksts :idea:
http://www.jblproservice.com/pdf/JRX%20 ... JRX115.pdf
 Post subject: Re: Dinamiki
PostPosted: 28-Aug-2005 17:53:44
iegaadaaties var pie autorizeetiem JBL dealeriem vai servisaa, ja veelies kaut pie manis. Visas 3 komponentes (LF, HF un filtrs) maksaas apmeeram 130 .. 200% no pashas AS veertiibas. Gruuti izteeloties motiivaaciju lai shaadaa veidaa komplekteetu sisteemu. Filtru var arii izgatavot pats, reiz reekjinaaju, ka leetaaks par ruupniicas tas sanaak saakot ar 42. eksemplaaru- ja vajadzigi daudz, tad var darboties, detalju piegaadaataaju koordinaates nav militaars nosleepums.
Ja pati JRX115 maksaa Ls 180 vai pat zem taa, tad viens pats HF drivers var sastaadiit pusi no shiis cenas vai pat vairaak. Tagad nav pie rokas komponentu cenas, bet varu noskaidrot, ja veel joprojaam gribeesies zinaat.
PostPosted: 28-Aug-2005 20:04:48
Cena ir tiesam par augsta.
Varbut jus varat piedavat speakerus un filtrus par pienemamu cenu.
PostPosted: 28-Aug-2005 20:17:54
ja iet runa ka pati tumba maksa letak, tad varbut ari nopirkt tumbu? nevis detaljas ... jo ir daudz preces, kuras izdevigak pirkt komplekta (gatava prece) nevis pa detaljam, jo tads ir firmas marketings un detaljas sanak dagrak ...
.. man shi te saruna liekas kaut kada jociga... no vienas puses lieta pa r pro, bet no otras puses .. ne..
Peace !
PostPosted: 28-Aug-2005 21:33:39
Taa vienkarsi sanaaca ka seit iesakas teema,gatava prece mums paslaik nav vajadziga
