It is currently 22-Oct-2026 1:14:36
 Post subject: monitori - skaņas karte
PostPosted: 05-Jan-2011 11:59:32
jautājums - vai viss skanēs, neatkarīgi no tā, ka monitori (alesis 520 usb) būs pieslēgti usb portam, nevis skaņas kartei (e-mu dsp 0404)?
PostPosted: 05-Jan-2011 15:42:42
http://www.alesis.com/m1active520usb
USB DIGITAL AUDIO INTERFACE
In addition to their capabilities as traditional monitor loudspeakers, M1Active 520 USB monitors contain a USB audio interface. Connected audio sources such as mic preamps and instruments can be recorded directly into your computer at 16-bit, 44.1 or 48 kHz. Simply plug the USB cable into your computer. No special drivers required. And when it's time to listen back to your mixes, that same USB cable sends 16-bit, 44.1 or 48 kHz, stereo audio from computer to your M1Active 520 USBs. No more complicated interfaces and messy cable tangles.
no tā ko raksta ražotājs var secināt ka var gan klausīties skaņu, gam ierakstīt uz datoru ar 16-bit, 44.1 or 48 kHz kvalitāti , un viss tas caur vienu USB vadu .
makintošu lietotājiem būs jānorāda kurš skaņas avots ko darīs. sustem preferences - sound - output, input .
Winlogs, audio control panelī arī var ieķeksēt vienīgo skaņas rēķinātāju .
PostPosted: 06-Jan-2011 19:11:40
a priekska tev skaqnjskarte vajadziga tad?
asio ar nav, un tt. klausities un dx rezima rakstit. vienigais ka erti.
