It is currently 20-Oct-2026 16:51:05
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
 Post subject: Vocal remove programma
PostPosted: 15-Jun-2004 10:10:14
Te kaads ieprieksh intereseejaas par vokaala remove iespeejaam no dziesmaas.
Tad luuk ir iznaakusi jauna versija programmai - YoGen Vocal Remover v2.0.9
YoGen Vocal Remover tries to remove any monophonic components from stereo sound. Quality of vocal removal depends on how songs are recorded and mixed. This software works very well for vocal tracks that are \"up in the middle\" of the stereo mix. Other placement of the vocal in the stereo field can not be removed. If songs are not recorded in this way, their vocals are not removed at all. This is why some songs work great while others do not.
MP3 file support has been added over the previous version. Now it can directly process an MP3 file. So you do not need to convert MP3 files to WAV files anymore.
PostPosted: 15-Jun-2004 14:20:27
Ej nu tu atrodi traku kam vokaals ir tikai "up in the middle".
Taapat jau vokaali tiek apstraadaati ar efektiem un mainaas faaze, taapeec remuuvoshanas rezultaats parasti nav spiidosh :(
PostPosted: 16-Jun-2004 10:01:09
prichome te faaze :) ? Vienkaarshi ir, ka vokaals aiznjem pietiekoshi plashu frekvenchu diapazonu pat saakot no kaadi 250-300 Hz liidz pat paaris kHz.Shai pat diapazonaa atrodas visas stiigas, dazhi sitamie, sintinju partijas u.t.t.Nu un ja grib sho vokaalu aizvaakt, tad aizvaacaas arii viss paareejais.Principaa viss atkariigs no materiaala, kaut kam jau pussekmiigi var aizvaakt vokaalu.Parasti tas ir "plikaam dziesmaam", kur ir tikai basbochka, snare un varbuut viens - divi sintinji.
PostPosted: 16-Jun-2004 15:58:43
Faaze te ir prichom vistieshaakajaa veidaa! Tieshi taapeec jau vinja ir jaaanalizee, lai atshtetinaatu to vokaalu no shii plashaa frekvenchu spektra! :roll:
http://www.mtu.com/basics/vocal-eliminator.htm
Uzliec sho mazo prograaminu, atver un uzspied read manual...un pamaacies draugs kaapeec taa faaze ir tik svariiga
:lol:
PostPosted: 17-Jun-2004 15:14:13
Nav man laika un veeleeshanaas likt uz pc kaut kaadu krapu, bet ja reiz tu raksti, tad varbuut esi tik laipns un pastaasti, "prichom tomeer tur faaze". Man ar rtu radiotehnikja izgliitiibu tas kaut kaa nav skaidrs. Protams, ja mees ar vaardu "faaze" saprotam vienu un to pashu. Mono vokaalam, neproceseeta, un ierakstiitam ar *vienu* mikrafonu faaze ir "ne v kassu".
PostPosted: 17-Jun-2004 15:51:53
Elektriiba un muuzika... Ak shii faaze 8)
Anyway faze vai nefaaze.... versija, ka vokaalu var izgriezt tikai nokillojot attieciigo frekvenchu spektru ir garaam :roll:
PostPosted: 17-Jun-2004 16:13:32
Bet es jau saku to pashu, ka killojot frekvenci vienam tu killo visam.Liidz ar to garaam.
Jebkuraa gadiijumaa, izskataas ka nevari paskaidrot par faazi...
PostPosted: 26-Jun-2004 17:57:24
incanti kaa lielie viiri atgriezh visu paareejo un atstaaj tikai vocaalu, tas taa buutu swariigaak nekaa nonjemt vokaalu =)
PostPosted: 22-Jul-2004 13:53:04
Esmu megjinaajis notiiriit vokaalu ar Cool Edit Pro 2 - rezultaats ir nekam nederiigs. Es domaaju, ka nesachakareejot foni nevar izgriezt vokaalu.
 Post subject: cycle
PostPosted: 22-Jul-2004 20:17:24
Ja te vajag soundu ( ritmu, melodiju utt) no kaadas dziesmas, kuraa ir pa virsu vokaals pats vienkaarhskais, lai sho problemu atrisinatu ir pieversties vecajam labajam tradicijaam johaid. Panjem kadu sounda editu ( soundforge, wavelabe vai ar to pashu cooledit ) un saac graizities - izgriezt fragmentus kuros ir pa virsu vokaals un tad kulturali daljas kuras ir palikushas, bez vokala samixee ... var ar attiecigi kadaa jaukaa sekvenceri to visu salimeet kopaa taa ka pat nepemana izgriestas daljas .... var ar izgriest 1 - 5 s garas cilpas, ja tu gribi taisit rmx un peec tam vinjas slaisot (cycle) uz jaukaa Recycle progas un peec tam bez probleeam play jebkuraa atruma cubase bez pitch defekta, bez tam tu veel vari to pashu rex formata loopu editot taa kaa tu gribi - galigi samainit jau no esosha songa loopa vai ar iznjemt araa dazhas perkursijas kuras tev nepattik - nu var visu, ja labi grib ....
 Post subject: Re: cycle
PostPosted: 09-Aug-2004 14:49:32
Semplus sataisiit OK tur nav probleemu. Jautaajums ir kaa uztaisiit 1:1 taadu pašu soundtreku kaa origjinaalajaa songaa? var ar izgriest 1 - 5 s garas cilpas -? ko dariit ar taam songa taktiim, kuras nav dabuujamas bez vokaala? limeet no cilpaam?, bet harmoonijas ?
Kaut kaa negticaas, ka tik vienkaarshi var izgriezt un saliimeet. teoreetiski varbuut.
PostPosted: 11-Aug-2004 16:49:14
Jaa gan tiiri 100 % ritmu tu neieguusi. Taaas vietaas kur ir vokaals, un kur mainas varbutt pats ritms, tu vari jau no igriezto cilpu variacijam uzmeistereet, tapee lieto rex formatu. Ja gadaas kada pilna melodija izgrieztaja cilpaa, tad ar nava problemu to visu samainit un parveidot zem rex formata. Nava tas viegli, bet ja tik ljoti gribi tad cinies. ja to dara komercialos nolukos taa skaitas zakshana.....
PostPosted: 11-Aug-2004 21:24:34
Pameginaju tās augstāk minētās programmeles. Tjaa... Ja grib mājās taisīt ģimenes karaoke konkursu, varbut tam pietiek, bet diezgan liets sviesc...
Ja man vajag kādu foņu, es to taisu no nulles. Noklausos gabalu, izpīpēju harmonijas, piemeklēju tembrus un...
Pamatā strādāju ar Reason 2.5 un ja vajag ģitāras, tad sasinhronizēju Reason ar Sonar3, kurā ieklimperēju Virtual Guitarit'ā gichas kādas vajag. Pārējo praktiski baxtu dzīvajā pa ceļiem, pēc tam izrediģējot. Bišķin apfrizēju SoundForge, mazliet uzkompresēju, lai liekās biezāk un dziesma gatava. Reason plis ir tas, ka tas ņem pretim VISA veida skaņas (žēl neņem VST) Galvenais ka arī SF2 (soundfontus). Var piemeklēt tādas skaņas, ka piemēram bungas gandrīz neatšķirt no dzīvām. Karoče, ja ir laiks un pacietība, un mazliet fiška - visu var izdarīt!!!!
www.mk-leja.lv
PostPosted: 13-Aug-2004 8:02:03
www.mk-leja.lv
šit :wink: ais labs
PostPosted: 16-Aug-2004 12:09:42
es neredzeju un nedzirdeju NORMALAS progas, kura var IZNJEMT vokalu, atstajot treku LABA kvalitate bez kropljojumiem...
